Posted by Janicholson on November 29, 2013 at 15:21:19 from (74.60.94.18):
In Reply to: 400 bolster removal posted by Fudd on November 29, 2013 at 15:10:39:
The pan will not hold any weight at all. Use the clutch housing behind the engine. Use more than just the jack, block it up with wood, not concrete. The lower bolster is heavy and very awkward. just jack enough to get the tires just touching the ground, and get help. The shaft is held upward by the nut on the sector gear. It is also (now) held up by the taper in the gear. It will need some love taps, and propane torch heat to expand its taper grip on the upper bolster shaft. Do not hammer on the threaded shaft you will destroy the threads, Out the nut on flush with the top, and use a brass or alloy aluminum buffer to avoid damage. The grease in it now is probably corn head grease. It is appropriate to use that, red Mobil 1 synthetic chassis grease, or 90 wt gear oil. The 90 wt leaks out far easier than the others. Jim
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
