Posted by El Toro on December 16, 2013 at 08:52:28 from (96.244.7.206):
In Reply to: '42 H Just Won't Start posted by Farmer Matt on December 16, 2013 at 07:30:46:
Pull No1 plug near the radiator and hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure. Once you feel pressure drop a long plastic straw on top of the piston. Watch the straw rise as the engine is slowly cranked. When the straw quits rising No1 piston should be at TDC on the compression stroke. Remove the distributor cap and see where the rotor is pointing. Should be the No1 plug tower. It it's pointing to No4 you're 180 degrees off.
Hold your hand over the throat of the carb while a helper makes an attempt to start the engine to see if there's much suction on your hand. Low suction means low intake manifold vacuum. Do a compression check. Hal
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
