Re: B rear wheels
Posted by gene b on December 14, 2000 at 05:05:14 from (63.15.137.33):
In Reply to: B rear wheels posted by Paul Shuler on December 13, 2000 at 20:31:36:
if the rims measure 9in on the outside you have a 8 in rim the bead of the tire sets inside therefore 8in outside is 7 the 9.5 is awfull big will cut power is it for show ect or are you going to pull it the 9.5 tire set in as far as the rim goes will not clear the fenders and the brake on the drivers side fenders can be moved inside of the housings check rim size been there done that have 6 B WITH ALL DIFF SIZE RIMS TIRES glad to help
Post A Followup
: Re: Re: B rear wheels
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
