1086 3 point hitch
Posted by gbs on January 12, 2014 at 13:36:05 from (71.51.252.209):
i removed the top link bracket to see how much piston seal leakage it had,as suspected the piston is seal leaking ,question is there are 3 more small streams of fluid coming from the right rear of the cylinder are these normal,if not i will try to locate their source,also does the lift use the same pump as the remotes
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
