Posted by Allan from PA on January 18, 2014 at 06:27:14 from (24.131.126.215):
In Reply to: Farmall h won't start posted by Brady miller on January 17, 2014 at 17:08:55:
Have an AV with mag that would do the same thing. After trying everything I could think of, put a new coil in the mag. Now fires up instantly every time. Got trouble if the spark is not hot enough. Also have a Case SC that one day would not start. Had good spark, good fuel and air. Pulled my hair out trying to figure out the problem. Finally put in a new set of spark plugs and it fired right up. Old plugs would fire OK out of the engine, but once installed would not fire under compression. Go figure. Good luck, Allan.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
