Re: Headlight switch wiring
Posted by sony224422 on January 18, 2014 at 13:30:15 from (50.133.160.171):
In Reply to: Headlight switch wiring posted by Jim Becker on January 15, 2014 at 22:03:26:
This is correct. I have the switch figured out. I ended up removing the original resister, and used a 10 ohm 25 watt in its place. I am running a hair over two Amps for leds so it brings them down to about 9.5 volts which looks nice at low power
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
