200 Runs!
Posted by Lmack on January 18, 2014 at 17:09:34 from (24.131.50.165):
I parked my 200 after the peas and corn were laid by and ran it very little. About Thanksgiving time last fall I needed to get it going to move some limbs and some other chores and I wanted to get the cultivator tool bars off for painting. It would not even try to start . . . no fire. You guys told me to clean the points and I put it on the round-to-it list. It came up today. I charged up the battery and used a very fine grit sand paper just lightly to file the points. (I haven"t seen my points file in years.) The first time I filed I checked the amp meter when I switched it on and there was a definite show of "discharge" which let me know it was clearly a points issue. Using the starter I rolled it over a few times and it was back to no discharge. I repeated the process until it sparked on every break. Put the distributer cap back on and it fired right up. Thanks for the help. If I had not been so stubborn I would not have a new coil on the tractor with an old coil now in storage that is just fine.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
