Re: cylinder sleeve issue
Posted by Jay Snyder on January 18, 2014 at 19:21:09 from (50.50.88.204):
In Reply to: cylinder sleeve issue posted by ziemerj on January 12, 2014 at 17:03:46:
Using a puller? Or trying to do it without? Heat up the sleeve a little and usually with a "slight" amount of force they slide out. Guessing the retainer is gone out of the block bore but could of got a little rust in it and rusted the sleeve in the block. Good luck.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
