Re: Clutch with torque amplifier on 460
Posted by mkirsch on January 27, 2014 at 11:45:18 from (65.199.189.6):
In Reply to: Clutch with torque amplifier on 460 posted by lanopie on January 27, 2014 at 09:17:27:
Which clutch did you replace?
There is the main clutch on the flywheel.
There is the TA clutch as Janicholson describes.
Your problem sounds like the TA clutch has failed, as Janicholson descirbes. Either that, or your TA adjustment is WAY out of whack.
The TA clutch usually goes because the adjustment was wrong. If you set the short linkage between the main clutch arm and the TA arm too tight, the TA clutch slips and burns up. Same thing happens if you adjust the TA lever linkage too tight.
There is an inspection cover on top of the torque tube (under the gas tank) that you can remove to look at the TA clutch.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
