It appears to be a late model F-20. Name plate should be on rear of tool box. serial numbers should be on that plate and also stamped on one of the frame rails, and on the side of the engine. F-20's and Regulars are very simular. most parts will even interchange. A regular has open steering gears, 3 spead transmission, and a different manifold carburater set up (down draft exhaust and no hole in the hood). alot of regulars and F-20's are found today bearing each others parts. for example a regular may be found with alot of f-20 parts on it.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
