Re: Steering rebuild Farmall A
Posted by gene bender on February 09, 2014 at 13:49:28 from (207.177.56.213):
In Reply to: Steering rebuild Farmall A posted by Keith Calhoun on February 09, 2014 at 09:59:11:
The parts you need wont come from another unit. You have bushings two bearings two seals gaskets and maybe a new key for the gear. To start with have you checked the drag link to see if it moves back and forth just mite be loose on the shaft. If it moves up and down the top bearing is shot. How tight are the tie rod ends and does the steering shaft move endways when you turn the shaft back and forth as the bearing on the end of the steering shaft mite be shot. You do need to remove the axle before you can take the sector apart as the bottom section cannot be removed until the axle is out and then the draglink needs to slide off as the bottom is removed. I have done several of them and with good parts and full of 90wt they steer like new again.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
