Re: calling...Al L in Wisc
Posted by Al L. in Wisc. on February 17, 2014 at 19:18:04 from (216.226.92.254):
In Reply to: calling...Al L in Wisc posted by Kirk Affeldt on February 17, 2014 at 17:26:36:
Kirk Affeldt; do you know if that 2001 specifically was on a Farmall 340? The rear mounting of the IH sub-frame and the front mounting brackets are 340 specific.
I am sure folks will state that if you have a welder or know someone who does, you can make it work; yes, but not original. That maybe isn't of any concern to you.
No power steering = big problem. I called coast-to-coast and filled ~ seven pages with numbers looking for same for several years = no luck. As Putter says, you will most likely need to find a 'donor' 340. For the hydraulics, an aftermarket single or aftermarket twin cylinders can be added if you have the remotes on your tractor.
Depending on your purpose for a loader, a heavy load can really strain the front end.
You probably already know this but, there was an optional tine cover, material bucket and snow bucket for the IH loader. My Farmall 340 with factory utility swept back front axle WITHOUT power steering is staying that way. I really don't have a use for one and no power steering, well.....
Regarding cost, ?? Steel lines, fittings, hose(s) if you need them, do add up; but a loader can save on your back as well. I wish you luck with your project. Many good folks on this board really love their 340's. More knowledgeable folks will probably chime in so watch your post.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
