My best guess (if pulling wire off a bit helps) is the plug is starting to foul. Id run a hotter plug, the 388 is a tad hotter then the original 386 but for a tractor that shows its age and/or its used for light duty Id run the hotter 388. HOWEVER and especially if its a Magneto Ignition, Id use the NON Resistor 3116 Autolite Plug.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
