Well the bull gears are not turned around, nor would it change the direction of travel if they were. The differential is what is flipped to drive the ring gear on the opposite side. Top is removed for access. The pinion carriers are removed the ring gear is removed and replaced on the opposite side, and pinion depth and tooth patterns are set (a little tough, but the service manual will have the setting procedure.) I do not know if the SC needs a different shifter rail setup, H and M do because of interference with the ring gear. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
