Re: 560 rpm ?
Posted by Tractordanp on May 06, 2014 at 16:24:05 from (50.137.83.148):
In Reply to: 560 rpm ? posted by tbish on May 06, 2014 at 15:14:00:
I had to free up all my linkage to help out it would only go to about 1600 it helped gain a bit but ended up having to adjust at the pump where linkage connects there are two screws one for low speed one for high speed they are maybe 5/16 head with a lock nut they go against a stopper
Just make sure all moves free then once you look at your pump it's on the engine side move from idle to full seeing if it bottoms out there is a spring that will allow linkage to move beyond either way if needed the screw towards the rear is high front is the low
Good luck and do a little at a time
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
