There are two kinds. Most were stamped plates, and the last ones made on the 650's & TD-91's were made from 1/4 inch plate. The reproduction Farmall MD ones sold by Bates Equipment are the 1/4 inch plate ones--they are the better ones anyway (I would consider them a factory improvement). Note that they all have a formed baffle welded to the inside of them--it is there to direct coolant flow through the block.
Yes, they can be made. The baffle complicates it a little since there often isn't enough left of the old ones to use for a pattern. Factory made ones would be the best route to go but that doesn't appear to be an option.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
