Re: Help needed to start 284
Posted by El Toro on May 08, 2014 at 04:07:32 from (96.244.7.206):
In Reply to: Help needed to start 284 posted by Oldihlover on May 07, 2014 at 18:21:48:
Check your compression and post the readings. Check your plug wires to make sure they're in the correct firing order. If you pulled the distributor I would bring No1 piston to tdc on the compression stroke. Then see where your rotor is pointing. Should be at the No1 plug tower. Hal
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
