Re: Farmall 140 Transmission NEED HELP
Posted by Janicholson on May 15, 2014 at 15:11:42 from (74.60.94.18):
In Reply to: Farmall 140 Transmission NEED HELP posted by RTR on May 15, 2014 at 13:43:07:
3 and 4 are on the same shift fork, so having it go into both at once is not possible.
There are detent balls and springs that keep a shift rail and fork positioned. If the springs are rusted/missing/broken, or balls missing rusted, it can allow rails to move where they should not, allowing the trans to be in 2 gears at once.
The balls/springs are in the cover, I would make sure they are operating as designed (easy as the trans can stay intact)
Make sure all three forks are correctly on their respective gears upon assembly. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
