444 3pt hitch
Posted by metalmender on May 23, 2014 at 16:15:11 from (71.127.0.86):
as my 444 warms up, the 3pt lift arms start to lift very slowly and this usually takes place after an hour or so of running, steering does not seem to be affected or the hydraulic remotes. are there "O" rings on the piston inside the top cover to actuate the 3point hitch? can this piston be removed out the front of the top cover to change the "O" rings? the hydraulic system is currently using IH Hy-Tran fluid
thanks in advance
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
