Re: Carb does not fit back on
Posted by Bus Driver on December 27, 2000 at 07:52:27 from (207.144.130.13):
In Reply to: Carb does not fit back on posted by RobertN on December 26, 2000 at 20:56:30:
I looked through the limited info here at home and did not find that carburetor. It is possible that it was not originally a tractor carburetor. My suggestion is to post on all the boards something like this. "My tractor has a carburetor that obviously is not correct. The carburetor is a Zenith with tag 10850A on top and B2 stamped on the bottom. Can you identify the equipment for which this carbutertor was made?" Most likely, someone can help you with that information. If that doesn't work, try to find a dealer who handles Zenith carburetors. I can give you the phone number of one who probably stiil handles them. Maybe yours can be sold to offset the cost of the one you really need. If it were me, I would plan to get the correct carburetor for the tractor.
Post A Followup
: Re: Re: Carb does not fit back on
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
