Posted by DeltaRed on June 22, 2014 at 06:43:10 from (65.100.146.82):
In Reply to: 826 hydro posted by shawn Alberts on June 21, 2014 at 18:30:57:
Simple test: Warm up the tractor well.Put in HI range.Open throttle to full.Step on both brakes at the same time.Smothly move the Hydro lever to full ahead position.The engine should stall or be SEVERLY overloaded.If you need more help of have questions,please call. (970)417-1178. Steve
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
