H Broke Aluminum Y-Yoke Mystery Solved
Posted by FBH44 on June 27, 2014 at 20:48:13 from (64.85.214.14):
Have been messing with clutch / pressure plate for a year now, long story, but I put in reman pressure plate, everything else like clutch plate, throw-out bearing, etc. was OK. The thing then vibrated bad, broke the aluminum Y-yoke carrier, the clutch pivot bar vibrated real bad in and out, I couldn't figure it out.
Time to fess up, so nobody else makes this stupid mistake; I had installed that 4-taper-bolt wavy joint ring BACKWARDS. Yep, it can be done, hard to do, but I did it. The drive shaft never even entered the pilot bearing, it was free to fling itself around, and it did.
Split the tractor, put in new pilot bearing, grinded the flywheel, installed everything right, it all works.
Just so nobody else makes this stupid mistake.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
