Take the pulley bearing and seal retainer bolts out next to the pulley flange. Pull shaft out keeping track of the shims. You can look at the shaft and see what needs done to change the seal. Other shaft only has one bearing and a bushing. Can get some idea of condition of it looking through the hole other shaft came out of. If you need to go farther the housing will not be as heavy when removing. Common for the bevel gears to give a rough feel when turning by hand.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
