Re: farmall a blowing white smoke
Posted by Janicholson on July 18, 2014 at 04:12:43 from (71.194.207.139):
In Reply to: farmall a blowing white smoke posted by Brandon S. on July 17, 2014 at 21:04:21:
The other posts are on track. If there is antfreeze in the cooling system the white smoke will have a sweet "different" odor to it. (If water is the coolant, it will not have odor.) As mentioned,it is an indication of coolant into the combustion chamber. Head gaskets, cracked heads, or cracked sleeves can cause the issue.
If it runs on 3 cylinders for a short time when started, it is surely that. After it sits over night, pull all plugs, leave the ignition off, and use the starter to spin the engine in neutral, no choke. Watch the sparkplug holes to see if coolant sprays out of one hole. Best of luck. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
