Re: 806 oil weep
Posted by Kenneth Updike on December 30, 2000 at 05:47:29 from (64.73.6.56):
In Reply to: 806 oil weep posted by Geoge on December 30, 2000 at 04:17:30:
On my 806 (SN #501) and on every other 301-263 gas engine the most common oil leak is on the side tappet cover gasket. The fix is to replace the gasket AND all 16 of the rubber washered retaining screws. Don't be afraid to use some RTV on the gasket either. Be sure to check the side cover for warpage.
As for your head gasket leak, does it get any better with a warmer engine?? Try retorqing the head bolts again. This may help.
Post A Followup
: Re: Re: 806 oil weep
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
