Re: ballast resistor/ IH 184
Posted by John T on July 22, 2014 at 12:48:04 from (216.249.72.121):
In Reply to: ballast resistor/ IH 184 posted by pilot199 on July 22, 2014 at 12:08:40:
Pilot, a Ballast Resistor used on coil ignition systems is more like 1.2 to around 2 ohms NOT 25 ohms. If a 25 ohm were used as a ballast resistor on an ignition system there wouldn't be any spark.
When people used a Delco 10SI type of 3 wire alternator they often used a diode while some such as myself used a 10 or so ohm resistor to prevent ignition feed back and run on. But that was in the EXCITATION circuit from the ignition or coil to the small side No 1 terminal on a 10 SI Delco alternator I HAVE NO IDEA WHAT YOU HAVE OR HOW ITS WIRED.
The big main output on an alternator would NOT go through a 25 ohm ballast resistor, it would go to an ammeter or the dash so it gets to the hot battery post eventually.
I don't know if yours is an excitation circuit resistor (like 3 wire Delco 10 SI used) or what it is but I dont see a 25 ohm ballast in the alternators big main output regardless of what alternator you have.
John T
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
