Re: ballast resistor/ IH 184
Posted by mkirsch on July 23, 2014 at 05:46:06 from (65.199.189.6):
In Reply to: ballast resistor/ IH 184 posted by pilot199 on July 22, 2014 at 12:08:40:
Hmm, the part about the mower killing the engine unless the tractor is moving is a strange one. It takes MORE engine power to move the tractor and spool up the mower, than it takes to spool up the mower just sitting there.
If the problem were electrical, I would expect the tractor to just stop dead like you turned off the ignition, not bog down. Does the engine recover if you immediately disengage the PTO?
First thing I'd do is loosen the drive belt and see if all your spindles are turning freely. Next, I'd try to fire up the PTO with nothing connected.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
