Posted by Centex Farmall on July 26, 2014 at 07:02:47 from (72.105.161.209):
In Reply to: 400 project posted by Ejtodd on July 25, 2014 at 20:51:15:
Any of them should turn via the fan. How much resistance of new vs. worn is impossible to gauge over the internet.
If you're thinking of getting it running like it is, drop the oil pan first to clean out whatever gunk is at the bottom and check the oil pump pickup screen for blockage.
With the hood off and the plugs out you can see part of the wall on each cylinder. Look for surface rust or if one cylinder is particularly bad. Sounds like it was just lightly stuck and that does happen, but sometimes water will leak around exhaust and one cylinder will end up bad.
Also if it's been in that same spot for 10 years, before I moved it at all, I would crack the drain plugs on the rear, trans, and pto drive and drain the accumulated water.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
