Posted by wayne in mn on July 28, 2014 at 11:36:42 from (71.8.150.168):
In Reply to: Re: Frozen key way posted by rustyfarmall on July 28, 2014 at 07:56:12:
Take the side cutter & grind the sides of it so that both cutting edges are shaped like a wood chisel. (single taper on each half of the plier, not two like it was from the store). This will let you get the plier cutting edge right down on the shaft and will give you the best grip to remove the half-moon key. Grip the key firmly and rotate the handle upward in a prying motion. Good luck.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
