Wheel Weight ID? Wondering if they fit....
Posted by jim on December 31, 2000 at 13:10:27 from (205.188.193.164):
Picked up a set of split wheel weights, one of them has IH logo with what appears to be a casting date of Sept 22 1939? (9*22*I)the part number on the weight appears to be 356109R2 with what appears to be a G underneath. With the two halfs put together the bolt patterns are 17" across from each other and 12" going to the next bolt hole, appears to have 3/4" opening for bolts. The assembled weight measures 23 1/2 in circumference and the roughly egg shaped opening
in the center measures 10 1/2 by 12 1/2.
Was told they would fit an H, used to seeing the solid plates on an H - wondering if they will, and if so can they be stacked? If they dont fit an H, anyone know what they would?
Thanks, and have an enjoyable New Year,
Jim
Post A Followup
: Re: Wheel Weight ID? Wondering if they fit....
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
