Not a flame!!! The new coil will not have an internal resistor. It will be designed for 12 volt to 15 volt continuous operation. The Windings are of finer wire and more of them. This provides similar total magnetic field density, while keeping the amp draw through the points at 3 to 4 amps. The reason for the confusion is that some coils indicate "for use with external resistor", others say "no external resistor required" These imply the concept that there are internal resistors within some. Not the case. Jim
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
