Posted by Owen Aaland on August 20, 2014 at 08:44:02 from (216.47.34.49):
In Reply to: ih 444 rear end posted by international606 on August 19, 2014 at 09:47:08:
international606 said: (quoted from post at 12:47:08 08/19/14) i was wanting to know what rear end oil capacity is for a ih 444 rear end. Also how do you check it. If I remember right it is hy tran and you fill it 1" below the fill hole on the right side of the gear shifter.
Standard oil capacity is 5 gallons. The plug to check the level is just under the step platform on the fight side, just ahead of the park brake lever. The front crankshaft mounted pump was an option for the 2444. If used the capacity was increased to 14 gallons and the level is checked by measuring down six inches from the fill plug.
This post was edited by Owen Aaland at 11:45:17 08/21/14.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
