Re: B275 tie rod end replacement issues
Posted by Duner Wi on August 21, 2014 at 18:59:14 from (216.226.80.242):
In Reply to: Re: B275 tie rod end replacement issues posted by Texandy on August 21, 2014 at 13:12:14:
The after market supplies both tie rod ends and drag link ends. They cost more than twice of Ford parts so you may be on to something.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
