Re: Gas problem?
Posted by rustyfarmall on August 31, 2014 at 06:32:45 from (208.126.186.41):
In Reply to: Gas problem? posted by Farmall4856 on August 30, 2014 at 14:47:05:
It is kind of an issue with SOME Ms. It needs to warm up a bit, then it will run just fine. If it doesn't, then you have an internal carburetor problem.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
