Re: IH 584 transmission top cover removal questions
Posted by Mark Robke on August 31, 2014 at 18:02:41 from (71.31.19.31):
In Reply to: IH 584 transmission top cover removal questions posted by jason mills on August 31, 2014 at 09:46:04:
The trans cover and the rear/hi-lo range will require the removal of the lines.They go off and on in a certain sequence,too.The trans cover will have the shift forks attached to the underside so you would have to raise it high enough to clear them over the housing sides.Mark
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
