Re: F-12 carb rebuild...Tom Fleming
Posted by Tom Fleming on September 05, 2014 at 02:44:56 from (67.20.239.72):
In Reply to: F-12 carb rebuild...Tom Fleming posted by Seth Boyer on September 03, 2014 at 20:25:28:
Seth, here is what I know. The jet itself is a press fit, no threads. it is a 1/8" (0.125) brass tube, with a 0.021 jet opening (#75 drill, hence the 75 on the part number) and a 1/16 (0.0625) id. The H and M jets would probably work, if you can thread the carb base. I'll have to look up the thread size again on the H and M jets. I also looked at using a Cub jet, and I know those threads take a 4-40 tap.
Lastly, there is a difference between a gas only carb and a dual fuel carb. That jet passes through a vacuum port. The gas only jet is a solid tube, and the dual fuel one has a port in the tube at 90 degrees part way up that opens into the vacuum port. I have a mostly intact broken one, and a NOS gas only one. I'll dig them out and get some specific measurements for you on the location of the dual fuel 2nd port, and also the overall length of the jet.
This post was edited by Tom Fleming at 02:47:51 09/05/14.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
