560 head gasket
Posted by Brad Vaughn on September 05, 2014 at 19:17:53 from (75.106.120.59):
Was working on a 560 gas tonight and was adjusting the valves. Noticed that a couple of the push rods were messed up and had a parts tractor that I could replace them with. When removing the rocker arm, I realized that they were also the head bolts. I should have drained the antifreeze down but did not know at the time. Put everything back together and retorqued the head bolts. I ended up with antifreeze in the oil so I drained the oil. My question is do you think the head gasket will reseal, or do I need to put a new one in before I fill it up with new oil. Thanks
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
