The upper transmission shaft was not spinning when the problem is happening. The constant mesh gears at the front of the two transmission shafts are spinning....I did not see if the lower shaft was spinning but I know the gears are spinning....thing slings gear oil out like crazy when I pop the cover off so I only looked for a split second a few different times.
Thanks for your help...what other info do you need to pinpoint the problem?
To me it seems like an issue further back in the transmission. I can put trans in neutral and push in the clutch and rotate the constant mesh gears by hand...put in gears 1-4 can't rotate constant mesh gears even with clutch pushed in. But when the problem happens the gears are spinning the shaft is not and the trans is in gear. Almost like it slipped i between gears although the shifter if firmly in gear.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
