Re: Farmall H Alternator Wiring
Posted by Owen Aaland on September 17, 2014 at 18:59:30 from (216.47.34.49):
In Reply to: Farmall H Alternator Wiring posted by fixer2u on September 17, 2014 at 13:59:52:
The alternator output post and the #2 terminal should have battery voltage on them at all times. The #1 terminal is controlled by the switch or what ever other method you have to provide power to excite the alternator. The voltage on this terminal will depend upon which method you used to control the back feed when the alternator is charging. Ideally this voltage should be at least half of battery voltage. If you use a diode in the #1 terminal circuit the voltage should be very close to battery voltage. If you use a light bulb or a resistor the voltage will be less. I do like to see less than about four volts with the switch on. The lower the voltage on the #1 terminal the faster the alternator will have to spin to begin charging. Once the alternator starts to charge there will be charging voltage at the #1 terminal so the alternator will continue to charge even at engine idle.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
