Re: New head gasket leaks on SA
Posted by T_Bone on January 03, 2001 at 01:02:29 from (207.254.52.201):
In Reply to: New head gasket leaks on SA posted by Robert in Md on January 02, 2001 at 20:09:39:
Hi Robert, I've only had to use a headgasket sealer one time and that was on a warped head that could not be fixed. Clean the head bolt holes out and check for length of the head bolts. If you find any more than 1/16" longer than the rest,replace the head bolts as there streaching when you tighten them. Retorque the head after a couple hours running then again after 25hrs.
Will grease work, sure but for how long. Find the problem of why they leaked first.
T_Bone
Post A Followup
: Re: Re: New head gasket leaks on SA
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
