Posted by teddy52food on September 22, 2014 at 20:16:09 from (184.94.175.179):
In Reply to: Priming oil pump posted by Joshua Rod on September 22, 2014 at 17:00:45:
If you used a good assembly lube when you put it together, just start it up & watch the gauge. It takes a little while to fill the filter but should have full pressure soon. Just think, every time you shut it off, & start it again, it has to run a while to get up full pressure too. And that hot oil drains off way more than a good assembly lube.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
