Re: IH 434 brakes
Posted by Rex in Australia on September 27, 2014 at 22:51:37 from (122.150.44.216):
In Reply to: IH 434 brakes posted by CanadianPowerWagon on September 26, 2014 at 09:15:25:
If it's all clean and there is material past the rivets they should
work ok.
Make sure the balls, springs etc are all clean between the
activating plates. one old trick is to put a slightly larger ball
bearing in. Takes up some of the wear, and changes where the
balls run in the ramps. may be worth a try.
People complain about the 434 brakes, but they work ok if
they are set up correctly.
Rex
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
