You will want to get a rebuilt clutch and pressure plate, and new pilot bearing for the flywheel.
The carb question has been covered.
The advice to get a new pedestal with matching hubs is good advice...not too hard to find. I have one myself if you would like it...reasonable. Located in Northern Minnesota.
As for moving the hand crank setup, taking out the cotter key only lets it slide backwards a bit...not to remove it. If you look closely, there is a stepped collar on the shaft end...it is very thin metal and you need to heat it carefully to slide it forward in order to drive out a straight pin holding the assembly together. Once that is apart, you can pull the shaft and remove the rest.
Get a parts manual or look up the diagrams on line to see a diagram.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
