Posted by rustred on October 14, 2014 at 11:27:39 from (74.214.153.210):
In Reply to: Starting my M posted by Dr. Bert on October 14, 2014 at 10:45:38:
what happens if you pull the choke first then crank? but from what i have experienced with these 6 volts is you need the fattest batt. cables and that makes a big difference on cranking. also the starter push switch must be in good condition, as there is two brass connections inside that either are worn or corroded. the one can be turned around also if it is worn.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
