Re: Farmall 450 Tork
Posted by Dugger on October 22, 2014 at 18:40:16 from (166.147.104.17):
In Reply to: Farmall 450 Tork posted by S2710 on October 22, 2014 at 06:48:57:
The TA in a 450 has very few parts that even run in oil
The sun gears etc
So yellow pail oil is fine
The main clutch is a dry clutch
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
