The brake master cylinders are on the engine side of the cab above the brake pedals. The clutch booster is in the same location on the left side of the cab. A cylinder leaking under the brake pedals is probably an auxiliary valve.
The transmission brake is internal in the bottom of the speed transmission.
There was a change in the park lock pawl and spring on the later tractors to make it a bit easier to get out of park. Later tractors also had an additional safety start switch on the park lock linkage allowing the engine to be started when in park without having to depress the clutch pedal.
The TA doing nothing when shifted could well be a problem with the cable. Either a locating clamp comes loose or the end of the cable or linkage is broken. An improperly adjusted clutch, transmission brake, or TA dump valve can all make the transmission hard to shift.
This post was edited by Owen Aaland at 22:12:29 11/10/14.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
