Posted by gene bender on November 12, 2014 at 07:47:08 from (67.55.226.121):
In Reply to: 53 sa engine posted by rray on November 12, 2014 at 06:44:25:
Clean the head and block well then give the new gasket a coat or two of hi-temp aluminium paint. Tighten head to 80ft lbs and then redo after getting warm and you should be ready to go. Had one that did same thing about 5yrs ago same thing as yours replaced as i said and it hasnt leaked yet
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
