Posted by The tractor vet on December 12, 2014 at 07:24:59 from (104.179.81.68):
In Reply to: 300U clutch posted by jeffcat on December 11, 2014 at 18:35:24:
Here is a trick i have used , The cover plate bolts are little SHORT 1/4 inch bolts and do not give you any wiggle room so ONE at a time remove one bolt and get ones that are about a 1/4 x1 bolt and put that in where you removed the one also to aid in this deal there are three shipping bolt hole in the cover and if and again i said IF my old memory has not gone completely i think they ae a 5/16th by one with a flat washer this will pull the pressure plate back against the cover plate and remove the spring pressure . IF the sprag is good you will be able to only turn the T/A flywheel one way so just work around it and once you have removed all the short bolts and replace to the longer ones just to holt it in place then you can take a pry bar and pop the disc loose from the flywheel. Once it loose then just replace the short bolt back in and remove the shipping bolt readjust the linkage and work it . NOW due to age ware and tare most times the BOOK INSTRUCTIONS for adjusting the linkage will not get the job done and here it comes down to a FEEL adjustment and you will have to learn that one for your self.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
