706 gas manifold
Posted by Central Illinois on December 26, 2014 at 17:15:48 from (162.72.44.124):
I went ahead and pulled the cylinder head off of my 706. The cylinder head checked out good at the machine shop so minor work was done on it. I went to my local dealer and ordered the gaskets and other things I need. There was a little sticker shock there. They didn't have everything in stock but I didn't expect them either. I started to clean up the engine today and get prepared for when my parts come in. I had to take the manifold apart because where the two halves meet the gasket was gone on one corner. When I got it apart the surface on the corner didn't look too good. While I was at it I freed up the heat control valve. Then I cleaned up the exhaust manifold. That is where I noticed more problems. It is cracked in three different places where it bolts to the intake manifold. I could probably put the assembly back together but I don't know it it will actually seal and I am not to crazy about the cracks. My question is has anyone bought a new aftermarket manifold assembly and if you did how do you like it? Thanks.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
