Posted by hendrik on January 16, 2015 at 08:30:58 from (84.35.5.78):
In Reply to: Re: C123 build posted by kub6040 on January 15, 2015 at 19:31:42:
Kub6040, why an all fuel head? A distillate head or a kerosene head has lager combustion chambers (and shorter valve stems) than the gasoline head, giving a lower compression ratio. Thanks, Hendrik
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
